Major update: Ace Attorney Online v4
Read and comment on the latest community news and site updates.
Dramatica
Re: Ace Attorney Online V4 is up and running !
Post by Dramatica »
Indeed. My only complaint is that the names kinda look messed up.
Meph
Post by Meph »
Unas, in the Autumn orchestral performance, there were four new tracks: Gumshoe, Emma Skye, Jake Marshall and the Blue Badger. I'll PM you when they're released on CD and I'll edit them for you. ;)
Perfect :wink:
I have the audience recording of these, but the quality isn't good enough :)
Meph
Post by Meph »
I have the audience recording too. It's okay, but.... m'eh.
Zero Kirby
Spoken languages: English, Very Poor French
Post by Zero Kirby »
Aheheh, this is kind of a late reply, but I do like the new system. There's a few bugs (can't delete cross-examinations or profiles for some reason), but so far, I like it a lot better; it's easier to create livelier trials.
I also REALLY appreciate the fact that the text box no longer appears if you just have shakes or flashes in them. Now my Objections are much more exciting!
Earlier Trials --
First Ever Trial: Turnabout Check-Out - Part One - Part Two
Current Series --
Episode One: Turnabout Detectives - Part Un - Part Deux - Part Trois - Part Quatre - Part Cinq
Turnabout Battle!--
Practice Time!
Dingzhu
Post by Dingzhu »
Ah. Well, you need to double-click to delete them.
Thanks to Jibbers for the avvie and sig! :nod:
Latest Trials
Turnabout Fortunes - Court-only
Turnabout is in Session - Day One - Day Two - D3 coming never.
Yes, important objects (such as CE blocks, or profiles) must be double-clicked to be deleted. That avoids loosing a lot of work with a misplaced click :)
Meph
Post by Meph »
Unas, I think that needs to be made more clearer. Maybe double click buttons should be red.
In fact, I could edit a lot of things in the case maker with CSS if you want. The design itself is fine, but I could add things making the text boxes use the Ace Attorney font and stuff like that. I know you could do it yourself, but since you're busy in your studies, I'd be happy to do it if you wish. :) You might need to add new classes, however.
Zero Kirby
Unas wrote:Yes, important objects (such as CE blocks, or profiles) must be double-clicked to be deleted. That avoids loosing a lot of work with a misplaced click :)
Is that active right now? Because I tried this, and it's not working.
Earlier Trials --
Current Series --
Turnabout Battle!--
Practice Time!
It works fine for profiles - but there may be an error with cross examinations. I'll have a look when I'm home :wink:
Indeed, there was an error with CEs that should be corrected now. Just double click the delete button ! :)
Locked
