That's one thing, but the twist of it will come shortly after I release the first part of the sequel. It's usually the Investigative phase before moving on the whole meat of the plot, which is at the trial. For now, I have to plot that case into an outline, brainstorm it with ideas, and then write it down in a document known as Google Docs.Enthalpy wrote:First, you may want to put that in a spoiler tag.
Second, if you want the player to be surprised that the case was much more complicated than they thought, I assume you want the player to be persuaded that the vigilante really did it?
Second, I made a sequel title of the story. Named "Turnabout Requite". Like that?
P.S. I will also use the same case writing technique here in AAO from this case plus the other case I made back in 2016.
