New scene.
New scene.
In the case i'm making, i finish the investigation in the crime scene, and i select "Reveal Scene" for have new things in Wright Anything Agency, but i go to the agency and nothing happens.
Re: New scene.
Maybe you never actually went to the frame where you reveal the scene. Maybe you revealed the wrong scene. Maybe you went to the wrong Wright Anything Agency. Maybe you just didn't see the difference between the two scenes.
I encourage you to see if any of those four possibilities are what happened. If you're still stuck, add me as a playtester to the case, and tell me when you add me.
Re: New scene.
Ok, i go to try.Enthalpy wrote:Maybe you never actually went to the frame where you reveal the scene. Maybe you revealed the wrong scene. Maybe you went to the wrong Wright Anything Agency. Maybe you just didn't see the difference between the two scenes.
Re: New scene.
As I suspected, the problem was that you went to the wrong Wright Anything Agency. You need to hide the old Wright Anything Agency and also create a move link from the crime scene to the new Wright Anything Agency scene.
Re: New scene.
How i hide the old agency?Enthalpy wrote:As I suspected, the problem was that you went to the wrong Wright Anything Agency. You need to hide the old Wright Anything Agency and also create a move link from the crime scene to the new Wright Anything Agency scene.
Re: New scene.
The "Hide a Scene" command, which is the inverse of the "Reveal a Scene" command that you've already used.
Re: New scene.
I use the "Hide a Scene" in the start?Enthalpy wrote:The "Hide a Scene" command, which is the inverse of the "Reveal a Scene" command that you've already used.
Re: New scene.
You use the command when you are ready to use it, at about the same time as you reveal the other Wright Anything Agency.
Re: New scene.
Ok.Enthalpy wrote:You use the command when you are ready to use it, at about the same time as you reveal the other Wright Anything Agency.
Re: New scene.
The new Wright Anything Agency not appears when i touch Move, and i hide the first and reveal the second.
Re: New scene.
Did you create a move link from the crime scene to the new Wright Anything Agency scene?
Re: New scene.
Ups.Enthalpy wrote:Did you create a move link from the crime scene to the new Wright Anything Agency scene?
Re: New scene.
I don't know what that means.
I played your case, and I can go to the new WAA just fine.
Re: New scene.
You can go to the detention center after go to the new WAA?Enthalpy wrote:I don't know what that means.
Re: New scene.
I can after I talk to the person at the Agency, yes.
