Is there a way we can add sound effects that repeat until needed to stop?
A case I'm working on requires music to be played in an area but also rain to be displayed and sound effected, I already considered adding the rain to the music, but I would like to know if there is a better way around(some kind of hack or technique) this so I could add a variety of music with the rain.
thank you!
Adding Continueous Sound effects?
Live life as you enjoy it, pal!-
I guess not...
I guess not...
Re: Adding Continueous Sound effects?
The way to do this is indeed to add the music. Having two tracks playing at once is an idea to think about... It probably wouldn't work on a mobile device, but we're not supporting that anyways.
Sorry, but what do you mean by add the music? you mean adding the sound effects into the music, right? (a suggestion I have if you would like to work on this in the future would be to add a stop all sound effects option in the sound effects dropdown, or in the sound effects menu an option to loop. But that would probably be too hard to implement)
thank you for the quick reply, Mr. Enthalpy.
I guess not...
I guess not...
I should have seen this earlier. Indeed, you'd add the sound effects as a music track. Sound effects play once and are done. Music tracks loop until stopped.Mosy wrote: ↑Mon Aug 02, 2021 4:40 amSorry, but what do you mean by add the music? you mean adding the sound effects into the music, right? (a suggestion I have if you would like to work on this in the future would be to add a stop all sound effects option in the sound effects dropdown, or in the sound effects menu an option to loop. But that would probably be too hard to implement)
Ah I see. so I guess that do be the only way round itEnthalpy wrote: ↑Tue Oct 05, 2021 3:56 amI should have seen this earlier. Indeed, you'd add the sound effects as a music track. Sound effects play once and are done. Music tracks loop until stopped.Mosy wrote: ↑Mon Aug 02, 2021 4:40 amSorry, but what do you mean by add the music? you mean adding the sound effects into the music, right? (a suggestion I have if you would like to work on this in the future would be to add a stop all sound effects option in the sound effects dropdown, or in the sound effects menu an option to loop. But that would probably be too hard to implement)
I guess not...
I guess not...
