Trial restoration
Meph
Trial restoration
Post by Meph »
Trial restoration
If you have problems saving your trial because it won't upload to the AAO server, don't worry, because you don't need to save your file! You can get your trial restored here.
But firstly, make sure that you do not close the Trial Editor until you have completed the steps below.
Follow these steps:-
  1. Click the "save test" button in the Save tab.
  2. Wait until the data is generated in the text box below it.
  3. Select all of the data (you can do this quickly by right clicking on the box and clicking "Select All") and copy it.
  4. Go to PasteBin.
  5. Paste your data into the text box. Then, click the save icon.
  6. Post the link to your bin in a reply to this thread, and give a link to your trial.
Once you do that, a member of staff will restore your trial as soon as possible.
Court-Records
Re: Trial restoration
Post by Court-Records »
Thanks Meph. =D
Court-Records
I'm having failure finding the 'submit' button. <_<
Help?
Tap
Post by Tap »
Click the little "save" button and then post the link here. Otherwise, post it in a .txt file (and if its too large, upload it to like megaupload or mediafire...)
Meph
Post by Meph »
Court-Records wrote:I'm having failure finding the 'submit' button. <_<
Help?
Sorry, there's no Submit button. I've fixed that in the instructions. ;)
Court-Records
Apparently, Pirate Pad also doesn't like my comp.
Here's a .txt file via megaupload. <_<
http://www.megaupload.com/?d=M6TP1WVG
Tap
Post by Tap »
Restored. :wink:
I don't know how much it did - considering it looks like there might have been only 3 new frames. :P
EDIT: What exactly is the problem that's not allowing you to save successfully on your end? It might be wise to post to see if anything can be done about it. :wink:
Court-Records
It's a 'watcher' type program that my parents installed to keep an eye on me. <_<
Not much I can do about it. It likes blocking server data a lot, and websites. Any web adress with a 'inappropiate word' in it gets blocked. Which can happen a lot when random keys get generated. <_<
And I hope there weren't just three new frames. I was working on that for a while. Huh.
Anyways, Thanks.
Court-Records
Have another .txt file.
It would be longer, but this is my backup one as my computer decided to shut itself off today. Thank you, brownout.
http://www.megaupload.com/?d=PUE9WK7O
Nevermind. I currently am looking at my trial, and nothing seems to be missing. O_O
My bad.
Meph
Post by Meph »
Done. ;)
Court-Records
me again.
It's short this time.
Ty.
http://www.megaupload.com/?d=9BUE67XF
Tap
Post by Tap »
Downloading the file now... :P
EDIT: Done.
Phantom
Post by Phantom »
A fine idea to have a sticky for this btw, nice job.
Court-Records
This guy again! I actually shut off my comp. Good think for back-up data. :D
http://www.megaupload.com/?d=A3FWJLGJ
Tap
Post by Tap »
Restored. ;)
Maybe you should ask your parents to remove the program if you need restoration every single time. :XD:
