It seems the GIF I'm using is too large and is not completely visible on the little screen, like a lot of it is cut off. Is there a way to remedy this?
Is there also a way to make it so the audio and video (GIF) only play once? I'm trying to put a video in a case by making it a GIF and playing the audio as music.
GIF I used is too large so it's cut off on screen
- Nicky Boy
- Spoken languages: Ελληνικά, English
Re: GIF I used is too large so it's cut off on screen
You can use ezgif to quickly resize your gif: https://ezgif.com/resize . The alternative, of course, is to do it frame-by-frame if the quality is not high enough for your liking, or find another method.
On the same site, you can then use this section and after uploading, specify "loop count" as 0. As for the audio track, using the "Stop current music" option in the editor should work once you are done with your scene.
