Formerly a terrible sprite comic, currently a not-yet-released game!
Two and a half cases of Kristoph Gavin: Ace Attorney were written way back in 2009, and, frankly, they weren't very good. however, there were some good ideas at the core of it all. Years later, I saw fit to salvage the series and make a fancase of it.
This will not be following the same continuity as the comic.
Set in the years between Phoenix's last trial and Apollo's first trial, Kristoph Gavin: Ace Attorney follows the cases of a bad man doing good things. After all, just because you're a dangerous sociopath with a history of violence doesn't mean you have to be bad at your job. And Kristoph is very good at it.
But what happens when his past tries to catch up to him?
The cases are as follows.
Meph wrote:Ooooh. This'll be good. I hope you're going to get it featured.
Why does it seem like that's always your first question to anything you find interesting here
† I have accepted Jesus Christ as my personal savior and am proud of it! Copy and paste this if you are too.† I love My Little Pony, Friendship is Magic and I'm proud of it! Paste this into your sig if you are too!
This is being worked on once again, as if the sudden revamps of the relevant sprites wouldn't have tipped you off.
Also, the comic, and the PyWright version, are now dropped.
It should now be mentioned that whilst the core plot of every case but A Lesson in Turnabout is fundamentally the same, the way each event unfolds is going to be quite different, for gameplay purposes.
I'm 400 frames into remaking The Grave Turnabout, but I'm focusing on fixing the graphics before I do any more writing.
Bumping this to notify you that The Grave Turnabout is nearing completion at 1067 out of approximately 1500 frames. I have nearly all the resources needed to finish it . Hopefully, this will be done within the next couple of months.
